First Time Charge and Weather.
xsong
On my Galaxy Note 2, I have a few questions.
1. Is first time charge important? If so, should I charge it out of the box without usage for 5+ hours or should I let it drain to 10% then charge it?
2. On my moms Note 2, I noticed on her weather app thing(the one that comes with the phone), when I click on it it shows me the 5 day forecast but only from 2 weeks ago, it won't show me this weeks.
Thanks for all your help!
There is no special rule to charging the battery. Some may tell you different. Just put the battery in the phone and charge it as needed. Plain and simple.
Typically the first couple times you charge your battery it would be best to just drain it down to 10% then fully charge it. The battery will usually take about a week to really get the maximum efficiency out of it.
Xsong - there's a little arrow symbol under the weather on the widget itself, press that and it will update. You can change the refresh settings somewhere but can't remember where sorry
