hey
i found the issue for anybody having issues with the 2nd verion of the app
when it is installed it installs Busybox 1.81.1
if you had a newer version it gets copied over and replaced
FOR SOME - causing stuck in cwm when booting
The other thing is
the app loads busybox into its data file
so Every Time you use the app
it i replaces your newer buybox with the older version of Busybox
I simpy uncompressed the app
removed Busybox
then zipped it
renamed to .apk
installed it and the issue is fixed
and i did it on my motion using root explorere
Note.
you can boot into this 2nd init cwm
by
repeatedly tapping the Back arrow while booting
This means you can uninstall the app if you want
the recovery files will remain in your system and continue to work without the app
But you need to run the app once to give it SU privilidges to install system files
