[FIX] "Call has been lost." - CM10
JJPR97
Some of you may have experienced an issue when you tried to make a call, it would say "Call has been lost." and then the call would not go through.
It's frustrating, but it's such an easy fix.
In a contact, sometimes you will have "+1 555-555-555" format, the issue there is the "+1". Remove it from the contact, and make it so it is only "555-555-5555" format.
When you make your call, it will work just fine.
It's a strange bug that happens on other devices, as well.
Well, I hope I helped some of you out. This bug drove me insane, for a few weeks. I couldn't send outgoing calls to my Father, but with the contact change I was able to send calls to anyone with the proper contact format.
