mmiranoc
Fix for SD Card Not Detecting Error in Samsung Galaxy Y S5360
It is very unfortunate that some of the users are having issue with the last firmware release of Gingerbread 2.3.6.
We have already reported the bugs which users are getting to the Samsung Electronics and we were told that the same will be fixed in the coming versions. So, now to fix the SD Card issues, you need not install any new firmware for the same but you need to follow a simple tip so as to fix it.
Tip: Backup all the data of your SD card in your computer.
Procedure to Fix SD Card Issue on Samsung Galaxy Y Android Phone:
First up, you need to backup all you data which is there in the SD Card as the data stored in the SD Card will be lost.
So, once the backup is done,
you need to format all the data in the
