andriodadmirer
HELLO THIS IS ANDROID ADMIRER HERE WITH THE FIX FOR THE LOCKSCREEN SETTING ISSUES THAT OUR STOCK KITKAT 4.4.2 ROM HAS HAD
O.K FIRST DOWNLOAD THIS ZIP IT'S THE STOCK SECSETTINGS.APK AND SETTINGS.ODEX
http://www.mediafire.com/download/ep1fpnvfp5hoczd/original_stock_settings.zip
UNZIP IT USING A FILE EXPLORER
TAKE THE NEW FILES AND COPY THEM TO THE PRIV-APP FOLDER IN THE SYSTEM FOLDER
SAY YES TO OVERWRITE THEM
THEN GO INTO EACH FILE AND CHANGE PERMISSIONS LIKE down below
AND THEN REBOOT
YOU WILL NO LONGER HAVE THE S5 SETTINGS OR MULTIWINDOW ANY MORE BUT EVERYTHING WILL WORK AGAIN
AND THEN REBOOT
