fix my internet
  • Start date Start date
A
Android Question
Guest
I have an unlocked htc inspire with a family mobile sim . how do I get my internet to work
That's not much information to go on.
However, my first guess is to check you APN settings (Access Point Names). These will be in the mobile/cellular data settings. Make sure these are correct for your network - you should be able to find the settings for your carrier on the web somewhere, either on your carrier's website or else a search will generally find them. These not being set, or not being set correctly, is the commonest reason people can't get the internet on any phone.
