Manuk Londong
Helllllllllllllllowww.... Every Body. Last Night Manuk Londong from Toraja_Indonesia just found a new way, HOW TO FIX NO SIGNAL/SERVICE FOR ALL QUALCOMM DEVICES.
Hire is the way :
1. your phone must be rooted and superSU already installed.
2. download android adb drivers and install it to your windows computer.
3. connect your phone to windows pc with the power still On.
3. enable USB DEBUG and allow connection with the computer.
4.open cmd as administrator and type "setprop sys.usb.config diag, adb" and press enter.
5. if in cmd you get error, install terminal emulator to your phone and type :
- su
- setprop sys.usb.config diag, adb
6. open device manager and see your device listed as hs-usb DIAG on COM-PORT drivers list.
7. download QPST and install it to your computer.
8. on your computer browser, open google search the android phone that has the same specification with your phone.
9. if you find it, open google again and search for that phone QCN FILE and downlod it.
10. after that, open QPST software downlod tool
11. see is your device listed there as COM conection.
12. select restore, browse for the qcn file (browse to the folder where the QCN file downloaded) and clik open.
13. click start.
14. wait untill the process restore complete.
15. if the restore process has been completely, turn off usb debug on your phone and disconect it from pc.
16. reboot your phone.
17. now the signal/service should be appear there.
now you can make a call or send a messege to another people. ☺
Hire is the way :
- su
13. click start.
