Arvind Rana
Well, there are some steps that you can try to fix this error. You can either -
1. Wipe Cache and Data of Phone app
2. Do the same for Sim TOOLKIT app
3. Wipe Cache Partition
4. Factory Reset
5. Change Battery Optimization settings .
Well, most of the users said that one of these 5 steps helped to Fix Unfortunately the Process.com.android.phone Has Stopped Error
4. Factory Reset
