Apps Flash CS5 extensions for android unavailable from adobe?? anyone know solution
Hello, I'm totally new to developing apps for android and am just getting started in flash CS5. According to most tutorials that I can find on the web I need to install an extension from adobe.
see this tutorial
Creative Sweet TV - Publish to Android 2.2 from Adobe Flash CS5 | Adobe TV
However, when I go to adobe's site they say that the extension isn't available anymore and will be integrated with their new version of Flash!!!!
Adobe Flash Professional CS5 Extension for Adobe AIR 2.5 - Adobe Labs
I just bought a new Mac to run CS5 and can't believe that now it looks like I'll have to upgrade my software, at more expense, in order to do something that was possible only a short time ago!!
Does anyone have any information on this problem?
did anyone have any luck finding the AIR extension? REALLY need this to complete my dissertation! any help or a point in the right direction would be great. Thanks
-Henry
Hi Helen, Bob and Star,
I'm in the same situation. I had used before this extension, but it seems Adobe stoped providing the tool, because it seems that with AIR 2.6, it will be integrated in the next version of Flash.
The other of doing this, it seems to be with AIR SDK, which can be downloaded from here (Adobe AIR * AIR Developer Tool (ADT)) I've not used it or tested, so I don't know , yeat, how it works, but it seems it will be through the command line.
Hope this will help you some how, since I'm about to test it myself.
Cheers.
I'm amazed how many people who don't read the posts clearly.
starscream9000 was kind enough to be willing to email this extension to people if they emailed him first!
