Mohammad_Adib
Adobe Flash has been removed from the Google Play store. Jellybean devices do not have Flash any longer, making the browsing experience no better than that of an iPhone.
Adobe Flash can be installed by just installing the newest version of the apk, which takes unnessecary searching on the web.
Hence, I created the app "Flash Installer", simply click install, and forget about it. It will prompt you to install flash and then disappear and never bother you again.
Download the app here and give your Jellybean device a dose of Adobe Flash. Boost your browsing experience!
Download (click image):
