Flash light not turning on
noor1
I have J2 (2016) in which I am facing two issues.
1. Flash light is not turning on.
2. Camera failed.
Now I want to know about how can I fix it.
I followed some suggested post and updated device's firmware. But the problem not fixed.
I attached the screenshots.
Hoping a quick response. Thanks.
Hey there! Welcome to the forums!
So before the firmware update, and again afterwards, you still have the same issue?
I would try 2 things.
Go into your camera app via the "manage applications" setting, force stop it, and clear out the data and cache.
Secondly, to rule out the torch issue, download a flashlight app such as Tesla Flashlight:
https://play.google.com/store/apps/details?id=com.teslacoilsw.flashlight
it has the bare minimum of permissions (be careful of other flashlight apps with outlandish permissions)., just to see if the torch works.
Go into your camera app via the 'manage applications' setting, force stop it, and clear out the data and cache.
Yes after firmware update still I m facing the camera fail issue.
And the link you provide is not valid. ... showing 'file not found. ...
