Help Flash not working in manually updated 2.2?
rival22
Anyone else having this issue?
No matter what web page I've tried, I get some form of an error message that I don't have a high enough version of adobe flash to play the video.
I've tried updating flash (v10.1.92.8) and didn't have any better luck so I reverted to the version on the phone. Any advice?
So you have successfully installed the latest version Flash v10.1.92.8? And with that version, sites failed to view properly?
I had a problem where 2.2 did NOT update my Adobe Flash....all Flash wouldn't view properly. I had to manually update to v10.1.92.8 using an APK I found on XDA forums. Afterwords, everything worked great.
Hope that helps
Ok... thinking about it this morning got me going in the right direction.
I re-installed the update, but it still didn't work. But it seemed more like a browser plugin issue than anything else, so I started looking at the stock browser settings.
For some reason plugins were disabled, and once I changed that setting, everything worked (although some flash videos were choppy, but that's probably just a network thing).
Now that that is fixed (and it wasn't even really a froyo issue), I'm a big fan of this update!
I downloaded the APK from XDA and still can't tell if Flash is working properly. Does anyone know where I can test that Flash works?
crunchyroll.com is where I tested mine. With Flash Lite, the advertisement videos would play but it would freeze when it was time for the actual episodes to launch.
Now I can watch them completely since I did the update.zip
Just annoyed Skype keeps launching itself...
