Help Flash on notifications
vipercwf
I just got the 4.3 update and my camera flash blinks on notification for emails texts and even phone calls. Is there a setting for this or just a 4.3 bug?
Settings > My Device Tab > Accessibility > Flash Notification..Make sure that's unchecked.
I think and hope that is what your talking about and that it works.
Cheers.
If not, I'm sure someone here will be able to assist you.
Cheers.
If it's not checked (and probably won't be) you have to check it, then uncheck it again to stop this.
Woke up this morning to my phone ringing, and the camera flash blinking! I was also notified that I'd just got an update...causing the same problem. Your advice worked. Checked and then unchecked that box, and it stopped! Thanks for your advice.
