mynameiskhan
hello guys my galaxy ace arm v6 is workin with flash player10.3 am using gb 2.3.6 s5830i n i downloaded the below file and installed and its workin
Adobe Flash 10.3 for ARMv6.apk
Graham.hello guys my galaxy ace arm v6 is workin with flash player10.3 am using gb 2.3.6 s5830i n i downloaded the below file and installed and its workin
How do you know it's working?? Most things don't need Flash! Have you specifically tried things that need Flash? Every other post here states Flash not working with any Stock or Custom ROM...!! Thanks.Graham.
Hi Khan, are you in the UK?? The big test is, will it play the BBC i-player!!wat u do give me a website name i will try that n let u know whether its working r not
Graham - London![]()
OK, Hi Hasanhello graham!...i am hasan khan from india
In that case we will try to find a website that we know needs Flash to work properly! Any ideas anyone, so that Hasan can test his Flash......?? Any suggestions PJ, apart from the obvious one which can't be put on here??!!
Thank u. Graham - London
OK, Hi HasanIn that case we will try to find a website that we know needs Flash to work properly! Any ideas anyone, so that Hasan can test his Flash......?? Any suggestions PJ, apart from the obvious one which can't be put on here??!!
