Root Flash Player
Adobe flash is not available on the market so remember that :) if you use the web to view videos keep it if not make a backup of it THEN delete as you might need it for the future
definitely uninstall. it a huge space taker and really unnecessary as most sites usually have a mobile version of their sites abiet with less videos but its better than having to carry that app on the phone
Use link2sd... then never worry about space again...
true true, ive always had one question about it though. do you have to partition the sd card? i dont feel like going to the trouble of partitioning it later on causing knowing me id mess up the sd card xDDD
From what I know partitioning is easy but it does wipe all data from SD so back it up to a computer depending on your SD partuotion what you need you can do it through CWM like on a 32 partition like 10 for link2sd (doesn't have to be 10)
No its not necessary to partition and I highly doubt it'll ruin the SD :)
i know it wouldnt necessary ruin the sd card as it would just be a matter of using minitool paritition to delete both parititions and and then re-establish the main partitition and set the sd id type: Fat32
