hi everyone what flash player do i need for my galaxy s3 i try adobe flash player but it says not available in my country its canada to watch my local network ctv.ca thanks for any help
have you tried navigating to the adobe site via your device?
the site should recognize what it is and direct you to the proper download
google play likes to add and remove variants of flash alot lol
If you're running Jelly Bean then you can no longer download it from Google Play.
If you google Flash on Jelly Bean you'll find a few guides on how to install it manually. You just find the .apk of the latest flash for Android and then use APKinstaller to run it.
