Root flash player??
ScarHead06
OKAAAAAY, Been brought to my attention that Adobe flash player is no longer working on any Android past 4.0 I'm on JB 4.1.2 So, what is a good/equivalent app I can install? I installed Photon Browser. Not sure exactly what it is but that's what popped up when I searched for flash player.
I'll check it out. Only reason I kinda need one was for a mock draft. It said I needed adobe flash player, clicked it, took me to a blank screen. Then found on the play store that adobe crapped out and hasn't upgraded that program for anything higher than 4.0. Jerks, lol. Maybe THAT'S why video playback is sketchy. Pry not tho, I dunno.
It should install and work with a compatible browser if you enable installation from unknown sources. However recently I have run into errors saying that my version is out of date.
Yeah, seen I gotta install dolphin. Was using boat browser, but if I need to use dolphin... that's cool. I dl the 1st apk on the list for flash drives, looked like the most recent one, lol. Buncha numbers. I'll use their site for the dolphin dl also.
