Flash Question/Problem
Harpua1
Hello Folks,
I did some searching on the Net and was told that flash v. 10.1 will work with android v 2.2. I downloaded and put it over on my sd card and when I try to run it, the installation runs then fails with "Application not installed" message, with my only option to click Done. At the google play homepage, It says that Flash v. 11.1 is not compatable with my device. I was hoping someone could point me in the right direction.
About Phone info is as follows:
Model Number: z800
Adroid version: 2.2
Kernal Version: 2.6.32.9-svn494
ljw@ntd-server2 #2
build number: z800_xn_p800_hvga_2.2GGV01.01B20_FL-Customer
Device ID: Unavailable (what's up with that?)
Thanks
Wes
I'm not sure what device this is, so I'm moving it to Android lounge. I hope you find the answer you seek!
