M millhouse6666 Lurker Sep 3, 2011 #1 If you flash your phone from the 2.3 to 2.1 will you be able to update it to the 2.3 after the flashing if i chose too.
beau420 Android Expert Sep 4, 2011 #2 millhouse6666 said: If you flash your phone from the 2.3 to 2.1 will you be able to update it to the 2.3 after the flashing if i chose too. Click to expand... If you go from 2.3....manage to flash back to 2.1. You could then flash back to 2.3. If your question is, can you upgrade or migrate data directly from 2.1 to 2.3 by running PC Companion or something. No. If you want to retain all your 2.1 data and go to 2.3.....then backup and to a factory wipe and then install 2.3.
