Look, I know alot of you already know about this, but I had a tough time finding it myself and figured I would help anyone else out if I could.
Downloads
1. I followed the link. Files I'm referrring to are under "Other stuff:"
2. Downloaded the "JH7 zip file OTA Stock" (which never worked for me as an OTA update) to my SDCARD.
3. Created a nandroid backup.
4. Disabled One Click Lag Fix.
5. Flashed the "JH7 zip file OTA Stock" from recovery menu.
The phone booted up almost stock with the update, has root/superuser but I had to enable non-market apps again, just like the first time I rooted. Also had to setup my accounts again...and apps.
Then I downloaded the "Stock Lock Screen" the same way and flashed the zip from recovery menu.
I was using the stock Captivate ROM - rooted and using One Click Lag Fix before, now I am using the updated JH7 ROM - rooted with re-applied One Click Lag Fix, and running the "vanilla" lock screen (screenshot below) rather than a glitchy Lockbot alternative.
Hope someone can get something out of this.
http://i394.photobucket.com/albums/pp22/AtariBorn/CaptivateVanillaLock.jpg
Downloads
