saxophown3d
So... I just made a pretty stupid error.
I recently tried to flash a newer version of TWRP recovery onto my Awe which was currently running an older version of CWM. I was in CWM recovery and then chose the TWRP file to flash and the flash completely successfully...
... or so I thought. A word of advice: Don't use the same SD card to install recovery for two different devices. I ended up installing a TF101(Transformer Tablet) recovery TWRP onto my phone instead of the correct recovery. Now, whenever I try to boot the phone, I can't get anywhere. If I take out the battery and put it back in, I'm greeted with a red light in the corner, but it doesn't advance further than this. When I plug it into my desktop, it doesn't recognize it. From the way I see it, my phone is bricked.
However, I was hoping someone could convince me otherwise. I would really, really like to be convinced. Does anyone have an idea of how to get into a proper recovery? I have a backup on the sd card along with the correct recovery zip, if that makes a difference. Any help at all will be appreciated!
