Root Flashed Firmware to "Stock" - cannot UNLOCK again...??
scudder
Android Expert
Hi Everyone...
Got 2 M9...rooted one and flashed ViperONE 3.5.0 ROM fine on the first one but problems on the second. Seems the second "newer" phone that I purchased needed the firmware upgraded to run he Venom ROM. I did that (with some difficulty) and I have 2.6.651.11 indicated in the download mode screen, HOWEVER, I cannot unlock the phone again. Oddly, it is as if the computer is only "partially" communicating with the phone. I can't find any devices when I execute the adb devices command. I tried to flash the token....won't. I try to issue the command to get the indentifier again....won't work.
I can't seem to unlock by flashing my previous Unlock_code.bin file.
I do get some "responses" in terminal such as the following:
unknowne4ce8f04aea2:sdk-tools sc$ ./fastboot-mac flash unlocktoken Unlock_code.bin
target reported max download size of 800000000 bytes
sending 'unlocktoken' (0 KB)...
OKAY [ 1.005s]
writing 'unlocktoken'...
(bootloader) flash unlocktoken
(bootloader) [KillSwitch] : /dev/block/bootdevice/by-name/frp
(bootloader) [KillSwitch] Last Byte is 0X00, disable unlock
(bootloader) [KillSwitch] oem unlock Turn Off!
OKAY [ 0.010s]
finished. total time: 1.015s
And here is the screen that I see.....DIFFERENT than when I unlocked my previous phones and my other M9 a couple weeks ago:
What you cannot see for some reason in the picture above is that below the red "download..........100%" line it says in white letter on a blue bar "Start downloading." At the bottom of the screen under "SD NOT Mounted" is "Under flash." When I hit the power button nothing happens except successive lines of "Under flash" appear at the bottom of the screen.
And "adb devices" command isn't finding any devices....HOWEVER, I seem to be able to communicate with the phone with various commands. My attempt to obtain my token again doesn't seem to be working:
unknowne4ce8f04aea2:sdk-tools sc$ ./fastboot-mac oem get_identifier_token
OKAY [ 0.055s]
finished. total time: 0.055s
I'm still S-ON and "relocked"....and thoughts??
THANK YOU!!
You need to go into developer options and enable OEM unlock in order to be able to unlock your bootloader. It's a new security feature in 5.1.
Thanks Kings! Yeah, after I successfully upgraded to 5.1 after all my problems, I thought I was ready to go...nope!! Wasn't enough to be a "developer" and to get as far as going to htcdev.com and moving forward to get the token. I needed a....CHECKBOX CHECKED!!
