Smoothpanda
i just flashed the nero v3 rom and i still get crappy battery life . Im about to download a task manager in hopes of that helping alittle but , is there anything else i can really do to fix this problem ?
You don't need a task manager. You have one built in. You probably need to train your battery, which will mean you need to wipe your battery stats.
Charge to full. Drain to empty. Charge to full with phone off. Boot in to recovery, then go to advanced, and wipe battery stats. This should set you straight.
also is there a reason why the app store has a really hard time downloading after you flash this rom ?
Its recommended that you recondition the battery after every rom flash; how you do that is to drain the battery fully, charge it up fully, then go into recovery and delete battery data...or something like this
Because I use Nero v3 touchwiz edition and battery life is good for me.
maybe its not that bad its taken all afternoon for the battery to drain.Your mostly right, after you drain the battery I was told that when you charge it to leave the phone off when you do it then when its full boot into clockwork recovery and delete battery stats or something like that.
