Root Flashing/backup ROMs??
barqers
Android Expert
Okay, I've been searching and searching for ways to backup my current ROM on this phone. I tried ROM Manager, but this phone isn't supported, so I tried using the i9000 ROM Manager, but it hangs when trying to backup my ROM. So I don't know if I really want to test another phone's settings incase it does worse damage.
So is there any way, maybe using a computer program, that I can backup my current ROM image? Wouldn't it be the same if I were to simply copy all my files from the phone's memory to a folder in my memory card using rootexplorer, then convert the folder into a ROM image? If this is possible.
Also, does anyone know any guides to installing froyo or gingerbread on this phone? I don't want to wait until April for Apps2sd, Samsung's updating is horrendous.
Try custom kernel for back up...
You can use rom cooker for backup your changed rom...
You can find this on xda forum galaxy 3 section...
