Root Flashing Dronix
2gambit1
I flashed Dronix to my m835 it worked but then when i rebooted it i wasnt connected to metropcs network what did i do wrong plz help
I had no 3G when I flashed Dronix and fixed it by flashing this. Did it take your UIM out? The only way I found around that was to flash back to stock or Mate35 and wipe everything. Then, once UIM has been restored, you can try flashing Dronix again, then the 3G fix. The zip for the fix is an Amend script, so you'll have to use something like Ultrajack to flash it (CWM 3.x and greater lacks Amend script compatibility) or convert it at your own risk. Kudos to EstebanSannin and everyone else involved in developing this excellent ROM!
