To get VVM working you need the APK from stock and to change the buildprop device ID to match the Evo V. MMS is WAAAY more complicated and often not possible.
MMS depends on the rom.Would you mind pointing out a thread that explains the mms fix, even if it may/may not work? I'm having a hard time searching for the solution. Thanks in advance!
Some need an older Hboot, some need a newer, red the descrioption. If it needs newer it will say so, otherwise youw ill have to downgrade. Remember, MMS will not work and neither will Visual Voicemail.
Radios, PRI and PRI don't matter for roms, usually. Some do prefer certain radios, but should work.
