Tweakforce_LG
I'm not too noligable on the ms323 but what's force closing? If its gapps I could possibly help
When I flash the ROM, all is well. As soon as I lock the screen and try to unlock it, it says "system ui forceclosed" over and over and will never stop. So I'm force to use 2-19 version of cm12.I'm not too noligable on the ms323 but what's force closing? If its gapps I could possibly help
Try cm12.1 not cm12 its on the lg l70 form buy the same developer. Cm 12 wouldn't install on my d320n due to md5 problems so try cm12.1 and use the twrp provided there. Its worth a shot mateWhen I flash the ROM, all is well. As soon as I lock the screen and try to unlock it, it says "system ui forceclosed" over and over and will never stop. So I'm force to use 2-19 version of cm12.
I can't find 12.1, is there a specific date that it is, or does part of the file name say 12.1?Try cm12.1 not cm12 its on the lg l70 form buy the same developer. Cm 12 wouldn't install on my d320n due to md5 problems so try cm12.1 and use the twrp provided there. Its worth a shot mate![]()
Cm 12 takes a while to flash sometimes it can take 15 minsok did what you said, exacly the same outcome, i flashed gapps to see if its a problem with TWRP and gapps flash fine. I really want cm12 not any other rom, so wahat now.
EDIT: i flashed Philz and it came up with the android recovery animation and factory reset my phone and restarted. No menu appeard. WHat now
