Root Flashing Verizon PRL
MizzouBrent
Android Expert
Is there a good, up to date guide for flashing a Verizon PRL? I'm fed up with Sprint at work and want to try this out. If I get good results, I might even switch over to big red.
Took me a while to find this but...
Download prl to root of sd card. then....
This was written for another person so forgive some of the basic instructions.
Obviously you'll need to be on a sense rom for the ## to work
HOW TO RESET YOUR PRL.....
GO INTO DIALER (LIKE YOU'RE GONNA CALL SOMEONE)
PRESS ##775#
WAIT FOR PROMPT TO ENTER PASSWORD (YOUR MSL)
ENTER msl code
SELECT UPDATE PRL
CHOOSE THE prl number THAT COMES UP
HIT MENU THEN COMMIT MODIFICATIONS
IF PHONE DOES NOT REBOOT ON ITS OWN, THEN REBOOT MANUALLY...
TO CHECK IF IT APPLIED,
HIT MENU, SETTINGS, ABOUT PHONE, SOFTWARE INFORMATION
(AT BOTTOM YOU SHOULD SEE PRL VERSION IS 00002 or whatever ):D
Well, I really don't want you to go to Big Red because I thought you were going to get the Sprint gnex. Yes, we need you over there. However, when I had my og Evo, I used the method described here to use the Verizon PRL. Worked just fine.
I also found an app on the playstore to read my msn. Sorry I am at work and don't remember the app.
[6/16]*techknowfile's* - Hack the HTC EVO - 3G w/o Sprint EVDO coverage! - xda-developers
