My S21 is similar. Pull down from the top left is notifications and from the top right a menu of quick settings. I use the right to turn my phone off. There is an off icon between edit and settings that I use nightly.I see I have to make a diagonal top right corner to bottom left corner swipe to get Quick Settings displayed. Flashlight now works.
Thank you olbriar
It's a two step exit but the one I use. The quick settings are easily accessed... I like that. Same thing with the notification list on the left pull down. I find it handy and yet not in the way.Thanks. I hadn't realized that off button was there. Too small to have noticed but good to have.
I had an s21 for 5 years and never realised that! I just pulled down once for notifications, again to expand the quick settings.My S21 is similar. Pull down from the top left is notifications and from the top right a menu of quick settings. I use the right to turn my phone off. There is an off icon between edit and settings that I use nightly.
Same here I use the three buttons more then the gestures thing.I had an s21 for 5 years and never realised that! I just pulled down once for notifications, again to expand the quick settings.
Mind you I also used the side panel feature to give me a set of toggles like that as well (I use the traditional 3 buttons rather than the navigation gestures, so I didn't have to worry about any conflict between swipes from the side).
