flyer keyboard
cm770011
has anyone used a keyboard for the flyer?
I can't seem to find any good ones!! I want a foldable one if needbe...
And I should be worried that none of the bluetooth ones say honeycomb or flyer right? I'm assuming that they are very specific for the certain models they work with...can anyone shed light on that?
also does a usb one work if we use a micro usb converter...
tks
Any standard BT keyboard should work. In fact the Apple BT keyboard works just fine for typing although the function keys don't work as labeled.
Having a keyboard is great for longer emails, I don't use it often but when you need it, nothing else will do.
The only complaint I've had is that the soft keyboard still sometimes fights to show up on the screen, but with the update it's easier to make the keyboard drop down.
Remember, if you've got a PIN code set on your lock screen it won't bring up the number pad to enter the code, it will expect it from the keyboard. The first time this happened I was a little confused as to what had happened, because I had put the keyboard away (but it was still with in range).
