Help flyer wont charge or connect to pc
I've had the flyer for 3 weeks and now it won't charge or connect to pc. Won't charge by either the wall charger or jab cable. Also the pc no longer "sees" the flyer when connect VIA usb. Any ideas? I've already tried the basics such as turning off and on and trying a different pc I doubt it the cable since neither wall or usb works. I also doubt its the battery since the pc doesn't see the tart when connected
I can't recall, but the Flyer has a sealed battery right? You may have to do a hard reset. Were you doing anything funny right before this happened? If you're a member of XDA, I'd post the question over there, it's much more lively and active in the Flyer forum.
connected
