Flytouch 3 10" 16GB 2.2 Google Android Internal SD problem
Nabeel929
I bought this recently, I think after i intalled several apps it got a problem with the internal SD. That when i open the Gallary it says "SD card unmounted or not present". I tried three options
1 Latest firmware update
2 Factory reset from settings menue also from pressing (Power+back+Menu does not work)
3 Bootable SD setup
any of these didnt work
so i think i have to remove the product and format the internal SD and copy fresh software.
Is this possible?
Please let me know
Thank you!
