N niXin Lurker Sep 26, 2011 #1 Hi I have a Superpad 2 Flytouch 3 Model number: disco Android version: 2.2-20110325 Base band version: unknown Kernel version: 2.6.32.9 Build number: FRF85B Wireless and network card have internet access I
N niXin Lurker Sep 26, 2011 #2 Hi Ok got the firmware installed had to format sd with sd formatter but 3g still not working Also the 3g icon on the task bar is gone When scaning for available service providers it ditects my service provider but I cant access the APN settings The dongle flashes blue 3g apps is turned on Gscript is on Got no idea what to do next Any help...
G gift4me Lurker Oct 21, 2011 #4 Which carrier are you using? Do you know if this will work for AT&T wireless (in US) Thanks.
