Help FM Radio Settings/Options - Problems
User guide for using the FM radio is non-existent! ! !
Questions:
1. How do I set station presets and switch between them?
2. How do I turn off the FM Radio? - I have tried hitting BACK several times, and removing the earpieces, but to no avail. When I re-insert the earpiece jack the radio is still playing.
Problem is, when I switch to watching a TV Channel, I then get both the TV Channel audio and the FM Radio audio at the same time.
Can somebody please help - it's driving me nuts ! ! !
Thanks in advance,
John:confused::mad:
There is someone here, but I'm not sure I can help!! :D :D I've not even found a way to play the FM radio yet on the Defy, assuming there even is one!!!! :o
Tap on the headphone icon to stop radio. I think there is no option available to preset stations. Not sure about it though
I had the same problem, and did some research. I am using Motorola Charm. Someone suggested turning the "Airplane Mode" on. That worked, and when the radio is off, you can turn the "Airplane Mode" off again. Hope that helps.:)
