Bought a new Galaxy A20. It ran Android 9. Yesterday, got the Android 10 and now, next radio won't work. Ok, I want an FM tuner that operates on/with Android 10. Seems a bit strange to me. Thanks! Rick
If it doesn't work with Android 10, but works with 9. it's probably the devs need to update their app for compatibility. Maybe worth you emailing the devs and enquiring.
just go into google play on your phone and do a search for fm radio apps. the ones that appear should work with your phone. or at least it will tell you if it is compatible with your phone or not. i have used tunein and iheart for a lot of my local radio stations and more.
Re: ocnbrze. Thanx for replying. Yeah... did all that. Ahmmm...most of what I came across was inet radio. Didn't find another "tuner" even after googling alternatives to NextRadio. Oh, did find a few "interesting" APKs that might do the trick??? Would have to give them a bit more scrutiny.
Damn...just wrote to NextRadio and inquired about an update. tube517 told me they are defunct. So... well, what next.? I'd think someone would have a "tuner" ??? Anyone know of one?
