On the inc when you go to add icons you can add folders. I started a new folder and put some of the inactive games I'm really not playing at the moment. Currently I see no way to rename the folder... Anyone know how to rename folders?
I know you didnt ask but theres an app called "Apps Organizer" that lets you label apps and then put folders on your home screen containing those apps. Its much nicer to use than the stock folder creator since it lets you put custom icons instead of the plain white folder that stock uses. It makes things easier to look at and not so plain.
EDIT WTF! Upther? This is Sal...
