folder short cut
Lineman69
Member
how do i make a folder on my sd card a short cut on one of my pages?? I cant seem to figure it out, maybe its not possible......
First thing you need is astro file manager. When you install that then long press on your home screen and select shortcut>astro. The file manager will open. Browse to the root of the sd card (don't open the folder) and long press the folder yu want a shortcut to. It will pop up a dialog where you can rename it, but you don't have to. then click OK and you have your shortcut.
