Folder Taking Up Much Space
JamesJoey
On my G2x I find a folder that I don't believe I'm using and is using up alot of space - \Gameloft\.
Is it safe to delete this folder and all it's contents??
James
Can you see how impossible it is for us to answer that?
Go to Settings > Applications > Manage and make sure the associated app is gone. If there’s no such app there, it probably left the folder behind when it was uninstalled, but only you can make that assessment.
Yes, you can delete it as long as your not using it. However, if there isn't anything saved inside the folder, then deleting it won't make a difference.
I noticed this right after I did a factory data reset, so I'm assuming it is something that is installed on the phone by default? That's why I asked. I have plenty of storage space at this time but I'm trying to determine what all this is on my phone.
James
Well, I have never seen “\Gameloft\” on my droid, or on its SD card, so if you want me to guess for you, I say trash it. That advice and seventy-five cents will get you a cup of coffee.
