folders for apps???
liquidmonkey
on my SGS2 it was easy to create a folder on any homescreen, just drag over one app onto another app and a folder was created.
but now in the G2 that function does not seem to exist :(
or have i missed something?
i have found some folder apps / widgets in the play store but they are not as good as what samsung had.
does the G2 have it and i have missed it?
any suggestions?
and i don't want to root my G2.
any suggestions?
Yes, this works. And, you can change the folder color too.
any suggestions?
No works fine, just drag one app shortcut onto another one and a folder is created.
If it helps any I noticed that I cannot create a folder or add to a folder if I'm bringing the icon from another screen. It seems like it has to be on the same screen to work.
