The one you mention is the one I have. Also did you activate Quick Circle in the settings?Thanks for your response..
Hmmm - I have just been to the Play Store and searched for Quick Circle... I get offered "Quick Circle Apps" by Yoav Stemberg and "Quick Circle PuppyPOP" by LG Electronics G3.
No "Quick Circle" for the G4... Is this because I'm in the UK? Will the G3 PuppPOP version do what's needed?
Thanks,
Roy
Did you turn on theOK - I have installed Quick Circle by Yoav Sternberg and selected Clock. Quick Circle is activated in the settings.
Now what?
If I shut the case - nothing happens.
Roy
I'm not sure. Don't have my case yet. What I am sure of is that you don't need the expensive case to make this work. My husband has G3 and has always used the Quick Circle feature. I've purchased the different cases, never had to buy the expensive one to have it work. Perhaps contact the app creator. That would be my next step.OK - I have installed Quick Circle by Yoav Sternberg and selected Clock. Quick Circle is activated in the settings.
Now what?
Roy
Did you turn on the
I'm pretty sure LG just wants you to pay a fortune for their case. It could be a month before my case arrives, but I'll let you know how it goes. If you figure yours out, let me know. There's got to be a way.I wonder if the G3 and G4 are the same? You would think so wouldn't you.
Exactly what case are you getting? When you have it please let me know if it works properly.
I really am not worried about the cost - if only I could get the product that I want! A folding case, without a bloomin great hole in the front, that sleep/wakes the phone on close/open. Is that really too much to ask!!!
Perhaps I will contact Yoav Sternberg - he may have an understanding of how this all works. But then - his position could be - "nothing to do with me if your case doesn't work"... Hmmm...
I would like to understand how this all works - I have Googled but there doesn't seem to be a good description anywhere on this. LG support first of all thought it was just a sensor on the front knowing when the cover was opened and closed - then later they changed their mind and intimated that there was some "special" electronics embedded into their cases that was sensed by the phone. Ho humm...
Thanks for your help with this.
Roy
ordered my case from Ebay Item # : 391156614214 It's purple. I like purple.I wonder if the G3 and G4 are the same? You would think so wouldn't you.
Roy
I got my cheap purple circle case from China. It didn't work. Tried it on my husband's G3 and it works. Tried just laying the cover on my screen and it works. Problem is, it's off center of the circle. I believe it's really made for the G3. You just can't get good quality for $5.14 (What was I thinking?) At least we've proven that it's not just the expensive LG case that makes the Quick Circle app work. Ordered a $15 case today, with qi charging...from the USA.
