clubanger96
does anyone think it would be possible for fonts to work on the avid?
oh ok thanks for the heads up guess I will wait till cwm is available for the avid thanks but it is possible for this phone to have different fonts right an also hows the progress on cwm for the avid anyone know
do you think at this rate we will ever get CWM to work
Because of this post, I used ROM toolbox to change my system fonts and it worked just fine. I also used it to customize my boot screen because I can't seem to find where the files are on my phone. I use "x-plore" and its not at system/media, infact i searched the whole root folder and it won't locate bootscreen.zip
And BTW, does anyone know where to find the splash screen files so I can get rid of that annoying metro PCS splash screen when I start my phone?
I wouldn't suggest it. I tried installing Emoji font through rom toolbox and resulted in my device being stuck at the Android booting screen. Downloading the update zip for ZTE hope it fixes this -.-
It will fix it, hope you had some sort of backup. I use go backup. I used titanium in the past but with the paid version of GO Backup, you can keep apps frozen.
