Sycobob
Does anyone know of a way to get the Alarm volume to change with the ringer mode? When I set my phone to vibrate, I want the alarm to vibrate, when I set my phone to silent, I want the alarms to be silent.
I have a couple of alarms set for to go off each evening. If I happen to go to the movies in the evening though, I want to be able to silence the alarms without having to go into the Clock app and do it manually for each one.
I often have to toggle the volume on or off based on what I'm doing, so I have a slider on my WidgetLocker screen for toggling between vibrate and full volume. I can't place widgets on the sliders, so I'm looking for a solution that will work if I change the ringer mode anywhere.
I tried Volume Control + but it only works if you use it's app or widget. I also tried Tasker, but it has no events for ringer mode.
Anyone have any suggestions?
