Root Force stop help?
RXFL
I was going through my apps because I was moving an app I downloded onto my SD card.
While I was browsing around, out of my stupidity, I accidentally force stopped Swype.. now I'm stuck with this stupid Google Pinyin or whatever and it's giving me a Korean keyboard.
I've tried everything but I can't get Swype back.
Is there any way to undo a force stop and get back Swype?
I'm going crazy with this stupid Korean keyboard.
this is actually a pretty easy fix. the app is just missing so put it back in. root_app_folder_Samsung_Admire.zip download that file and inside are the system apps. find the swype apk and you can either adb push it into the phone or use root explorer and move it into the system/app with the correct permissions
oohh and that korean keyboard you can safely delete lol same with the google pinyin keyboard. do you not have the android keyboard???
_________
UPDATE!!!!!!
oh wait you forced stoppped swyped.. i misread this.... you can simply reboot the phone. that always works with all my force close issues will all my apps
so i just forced close swype and to get it back all you simply do is hold the box you write text and "input method" will come up. just switch it to swype.
