Help forced auto rotate not working
I downloaded the app for forced auto rotate and it was working fine but there were updates today and now its not working. Any help would be appreciated because I have only had this thing for about 2weeks.
Thanks
Thanks
Are you rooted and did you make a backup of your apk file, so you can revert back to the previous version? If not, go online and see if you can find a copy of that apk (previous versiin), un install your update and install the apk you downloaded. Do not update again until issue is resolved.
Lessons learned:
Always read reviews of new updates for your device before downloading.
Back up your apps a couple of times a month (requires rooting). Create at least one Nandroid backup.
Save yourself big headache
Yes they issued an update to roll back their last update that had some major problems. Just down load the latest update and all will be good
