Been googling for over an hour to find a simple app with a widget thatll let me force my phone to roam, does one even exist.
Case is my provider (Oister) has perfect data coverage, but when im inside my house, i have such poor connection that i cant make calls without being cut off so i have to redial and thrughout the call therell be massive dropouts.
However my provider has free roaming thru another provider (TDC) which has perfect coverage accross the whole country.....well for making calls its perfect, because their data coverage downright sux. X-)
Problem is that my phone (SGS2) doesnt roam until the signal has been totally missing for about 1-2 full minutes and that hardly ever happens. *sigh*
So what i want is a widget that allows me to simply force my phone to use the roaming network when im at home, so far its the only place i dont get proper signal from Oister anyways.
I found one app so far that turned out not to be compatible with my phone and another which required rooting.
Then i found a third one (Network Switcher Pro) which i cant download because the links for the download dont work.
Hopefully someone in here will have the magic solution to this issue.
Oh btw, i contacted both Samsung and Oister complaining about the roaming issue, like how the phone can be set to roam on less reason, like when the signal drops below -95dbm it shd roam as that would be adequate.
Oister says its Samsungs problem as its the device that controls the roaming functionality and surprisingly Samsung says its Oisters problem as THEY control the roaming functionality. :hmmmm2:
