Sammynacole
I cant make or receive calls or texts. How do i fix this? I didnt knkw what fixed dialing was so i was playing around on my phone and make a pin and forgot before i realised what this feature was. Oops
you can talk to your provider as @Hadron suggested or you can try a hard reset. just keep in mind that you will need your origiinal google account info.....so make sure you know what that is before doing a hard reset.....otherwise you will trip FRP (factory reset protection). what device do you have?I cant make or receive calls or texts. How do i fix this? I didnt knkw what fixed dialing was so i was playing around on my phone and make a pin and forgot before i realised what this feature was. Oops
I once needed the code, my carrier were able to give it to me immediately. Guess some carriers are more competent than others.
I'd think that just telling them that the phone is asking for it would be enough information.
