Forgotten Pin
  • Start date Start date
A
Android Question
Guest
Hello!
Okay so I have a Samsung Galaxy Tablet 2 (GT- P5113 ) and I forgot my pin.
What can I do? I dont want to lose all my data and pictures...
Is there anyway to disable the lock screen? Maybe temporarily so I can download my data really quick?
Unfortunately I have not enabled usb debugging so I cant do anything like that.
I have heard that if you use a sd card with an aroma manager file you can bypass the lock screen.
Does that work? If it does, then how would I download the file to the sd card?
Thanks for reading :)
Plus, for some reason, the tablet doesn't ask for my google account when I missed the pin numbers. However, I did connect my tablet with my email.
