I installed STOCK++, booted up the phone, wanted to format the SD card and the phone itself. THEN the phone restarts, and instead of booting back into the stock it always jumps into CMW. Im not formatting from the CMW.
I think when you format through the 'settings' option you are effectively deleting the custom rom (in your case stock++). So when the phone restarts, there is no ROM and it reverts to CWM. Jusy my opinion; could be wrong.
Why do you care to format once flashed to stock++? After a fresh flash there shouldn't be any unique user data. If you want to format your sd card, you can do that through CWM.
