makewayhomer
I'm trying to install cyanogen mod 7 and wiped my sd card. now the install "won't take"...it won't mount the card, even though it WILL install the card. in clokworkmod recovery
I think the problem is my card. how am I supposed to partition it? I need to do it on my computer since my phone wont boot
I wipe everything. then I install CM7. then when I go to apply it, I get the message "E: Can't open /sdcard/update.zip (no such file or directory)
installation aborted
