Hi, to forward SMS press & hold the message & the options will appear. To delete widgets, press & hold & a "remove" box opens at bottom of screen. Pull widget into the box. Voila!! Hope that helps. GrahamF. London
That just indicates what has been using your battery.
All you can do is let it drain to minimum(before phone shuts down) and then charge to full every time. That keeps your battery running well. Search for a method to callibrate the battery, that might improve some numbers as well.
There is nothing much to do here, the battery is just too low for the device, it hardly lasts a day, its the same with most of the smartphones these days, the performance bar is rising everyday while the battery technology is runnning way behind.
